996 Termignoni Db Killers
Discussion in '748 / 916 / 996 / 998' started by Valespark, Mar 1, 2023.
Tags:
  1. Hi,
    Has anyone got a set of db killers for sale, or can anyone post a picture / drawing of set. Seen a few copy sets on eBay, but unsure which ones suit
    Thanks
  2. What size are your Termis, I’ve got some but would need to check sizes
  3. From my own experience, generic DB killers can be a poor fit. See the link below, this person made a couple of custom sets for me and they include an adjustable baffle.
    You will need to give him the silencers in order for them to be made up and for a perfect fit. I found the sizes (tolerence)of my exhausts varied by a fraction and therefore you need to use the correct one to fit the correct side
    if you mix them up.
    http://www.mhpexhaust.co.uk/
  4. I had generic dB killers on my 916 Termis for trackdays and MOT purposes. They fitted fine.
  5. Hi, it’s a 50mm system
  6. I’m in the same position, need a set of baffles for my 50mm termis on my 996. There’s no way they’d pass . @RickyX where did you get your generic ones from?
  7. From eBay.
  8. Are they the straight type, or with bend?
    Does anyone have a picture they can post?
  9. Mine were straight.
    They weren't the prettiest things but did the job required of them!
