899 Termignoni Exhaust 96480221a
Discussion in 'Panigale' started by Cake, Feb 7, 2017.
  1. Hi, had a search but cant find what I'm after.
    I'm looking to buy the slip-ons without the up map or air filter which comes under item no. 96480221A.
    Does anyone know if these do come with the DB killers and fitting parts?
    Everything says they are 94DB, assuming with the killers in as I'm not aware of Termis without killers.
    I assume they do but im looking to buy from abroad as cheaper and the English isn't translating well.
    I will be buying the air filter and T800 up map to complete it separately.
  2. Hey there,
    I brought my termis new a few weeks ago came with decibel killers installed in the slip ons, one Allen key bolt holding the killers in each side.
    Mine also came with the upmap and the air filter too as part of the kit. I would imagine if your buying the Kit new it will come with everything needed for the job. I looked at my invoice from Ducati and couldn't see anything extra on there...
    I hope this somehow helps. But if you in anyways unsure, I would just check on where you are buying it from.
    Cheers
  3. That part number is the complete kit. Silencers, air filter, fittings and upmap. No need for anything else
  4. Thanks - a few places you can buy just the silencers and explicitly say there is no filter or UpMap but still has the full kits number...
    Id assume the silencers were all the same just parts omitted.
  5. That part number is for the complete kit for the 899 from Ducati. If you're not getting filter and upmap then there's something amiss.
    Drop us a PM if you like and see if I can sort a deal for you?? ;)
