Testing Electrics
Discussion in 'Technical Help' started by Ghost Rider, May 3, 2012.
  1. Is there a polarity to be observed when using a multi-meter to test the pick-up coils?
    Thanks AL.
  2. No, as you are measuring the resistance across the coil in Ohms
  3. Cheers Phil.......I just wondered if there was more resistance in one direction than the other......
    I'll sort this d*mn bike out if it kills me......
    AL.
  4. OK...a bit further on......both pick-ups seem to test OK at 96+ Ohms (I guess they are OEM....but even so, I have now seen two figures for the OEM pick-ups in the versions of the 750/900 workshop manuals...........100 and 220).
    Anyone happen to know what readings for resistance I should get on the coils primary and secondary windings?...The workshop manual seems a bit wrong with the secondary winding at 3700 Ohms.......
    AL.
  5. Al
    The specification of the secondary winding resistance is between 10,800 ohms - 16,200 ohms, and the primary: 3.8 -5.2 ohms ( from my Haynes manual)
    What sort of meter are you using digital or analogue? what range is the meter set to for reading for the secondary coils?
  6. Using a digital one.......tested six coils....all primarys are approx 4.5 - 5 Ohms.
    Secondarys are 13,000 on the oldest pair and on the newer ones 15,000+ (the ones on the bike are 15.5 approx).....
    Setting the meter @ 20K for the coils and 200 for the pick-ups.
    Cheers....AL.
  7. All within spec' then Al, that's a relief! One less thing to worry about, you can sleep soundly tonight!
  8. Hi Al,
    From a past headache check the ohms while heating the pickup coil up in hot water.
    I had a fault on my old dd race bike and it would only drop onto one cylinder when hot.
    I found what was wrong with it out of interest after i fitted 2 new pickups.
  9. I don't think I have a coil problem, bearing in mind I have tested six of them all with similar readings.........
    ........and the running problem occurs as soon as the bike is started, so they really don't get much of a chance to get warm (that includes substituting coils and and the CDI boxes)
    I'm fairly certain it isn't 'electrics' as such......unless the flywheel is a bit loose, but I reckon that would affect both cylinders if it was.
    I'll have a look at that when I have got the carbs back on and tried running it again.
    AL.
