1200 Throttle Tube
Discussion in 'Multistrada' started by Neo9686, Jun 10, 2020.
  1. Hi. Do someone here know about a compatible aluminum tube for the first Multistrada 1200? I found just the G2 Ergo that comes from the US and is a bit pricey. If I remember correctly the stock throttle control is a Domino unit, the same kind used on many off road bikes, a compatibility should be easier to find... I guess! Off road bikes have 30/40 euros tubes to choose from, and even some interesting model that comes with bearings. The problem is to find this compatibility, as first thing.
    Thank you very much
  2. Try looking at Active. They’re a Japanese company. I’ve used them for special 1/5th turn on an R1.
  3. Thank you, I sent them an email since I can't find the tube on the site
