Getting the callipers off is a piece of piss. Use the disc and a fulcrum and turn the calliper towards you. This pushes the pads back against the pistons, which go back, giving you the room to get the calliper off the wheel
Don,t forget to take off the reservoir cover when you push the pistons back, and make sure it does not overflow on to your paintwork!
