1200 Torque Settings For Ohlins Forks
Discussion in 'Multistrada' started by mary hinge horse burger, Apr 19, 2016.
  1. Hi, can anyone help me out with some torque settings for a 2012 1200s (ohlins) please? Just has a fork seal done so need to put it all back together.
    I need torque settings for top yoke, bottom yoke, brake calipers and front axle.
    Thanks
  2. Front fork
    Bottom yoke terminals M8x1.25 16* GREASE B:sequence 1-2-1
    Central tightening screw on steering head M8x1.25 18* GREASE B
    Front pipe grommet to steering base fixing screw M6x1 10
    Handlebar on head stud screw M10x1.25 45* LOCK 2
    Handlebar U-bolts fixing screw M8x1.25 25*
    Marzocchi fork end terminal fixing screw M6x1 10* Sequence 1-2-1
    Öhlins fork end terminal fixing screw M8x1.25 19* Sequence 1-2-1
    Splash guard to steering base fixing screw M5x0.8 3 LOCK 2
    Steering bearing ring nut M35x1 30* GREASE B: sequence 1-2-1
    Steering head terminals M6x1 10* GREASE B
    Steering limit switch register lock nut M8x1.25 18 LOCK 2 on thread nut only
    Front wheel
    Disc and phonic wheel to wheel fixing screw M8x1.25 25* LOCK 2
    Front wheel shaft nut M25x1.25 63* GREASE B on the undersides of the head and threaded pin
    Front brake
    ABS control unit bracket fixing screw AF5 3
    ABS sensor fixing screw M6x1 10
    ABS tube cover on electrical components housing fixing screw AF5 3.5
    Front brake fluid reservoir to hand guard fixing screw M5x0.8 2
    Front brake master cylinder terminal M6x1 10 Sequence 1-2-1 starting from upper screw
    Front brake caliper pre-tightening M10x1.25 2
    Front calipers fixing screw M10x1.25 45* GREASE B
    Hand guard to pump fixing screw M6x1 10
    Hand guard to terminal fixing screw M5x0.8 5
    Throttle twistgrip fixing screw M6x1 10
