Got a 999s with Termis on it. No idea what the Db level is, but suspect it might be a bit toppy. Can anyone give me a clue on what it's likely to be and which tracks I'm most likely to get on without too much of an issue.
Excellent, thank you. Good for a 105 then. Did they let you on at Snetterton? I thought it was a 102.
It is 102db for Snetterton as far as I remember from last year. DB killers are a must as it is so easy to fail and if you don't have them then you might not get out, better safe than sorry.
I had mine custom built by Mark Hill of MHP Exhausts, he is very well known in the club racing world. Mine are stock DB killers for a 748-9** and were made to the correct internal diameter for the set of pipes I use. He also makes a custom adjustable DB killer that will go down to a very low figure so you would be absolutely assured of passing with that in. He can be reached here MHP Exhaust
He is one of the best, not the cheapest but you will get a quality item from him and he does stand by what he puts out. Good luck.
