1200 DVT Trouble Changing Load Settings
Discussion in 'Multistrada' started by Pestorello, Apr 1, 2018.
  1. Good morning all,
    I have recently bought a 2016 Multi 1200s and are unable to change the load settings from rider only, to ruder and pillion, it has the full colour tft dash. Can any body please assist?
  2. Make sure you’re using the bottom left corner of the menu enter button not the middle, otherwise give us a bit more to go on :)
  3. Have you read the manual and are you following te instructions with ignition on?
  4. Press and hold the down button on the Menu switch, not the Cruise switch. The options will appear on-screen. Cycle through by pressing the down button. Press and hold the down again to select an option.
  5. Its a bitch i have just done mine. The main menu does,nt do it as you select & save & then it just reverts back to origonal. As said above you need to hold button 2 down until the rider menu comes up. Button 2 is the back of menu button.
