I'm buying an STM Evoluzione so the current clutch off my baby will soon be available. It's a TSS (same as Yoyodyne in the US) spider spring type slipper with an EVR 48 tooth basket and sintered plates. Plates are still in good condition, I'll measure the friction plates once I have the clutch removed. Has worked flawlessly and the feel with a 29mm Oberon slave and the lithium grease trick has been superb. Slightly customized by polishing the spring caps and replacing the bolts with titanium bolts. Pressure plate bearing has less than 2000km on it. The center nut is M20 so it will fit all older Ducatis (not 1x98 with M25 nut). I'm pretty sure the center nuts are available separately though. Will also consider selling the pictured DP carbon clutch cover. Asking 599$~395£ for the clutch and 70$~45£ for the cover (only with the clutch, not separately). Located in Finland, payments only by Paypal. [email protected]
FWIW - I've bought stuff from @jusutus for some time now and I've never had any problems. Everything I've received has been in as good, or better, condition than expected. GLWTS
Mate ET's a keen fucker right enough! @dynoman - mate I doubt you'll regret it - all his stuff is in excellent condition or priced more-than-accordingly and still accurately described. Oh and have fun banging it down!
