Posted: Mon Aug 21, 2017 9:15 pm Hey For sale is all the HW needed to reflash your MTS 1200 Mitsubishi ECU with the Tuneboy SW , also included is the Quickshifter HW (strain gauge)to enable clutchless changes both up and down , with auto blip on the downchanges You just need to buy the SW key of your choice from Tuneboy Standard features include live mapping, readily available maps EXValve elimination, Launch Control , ability to load 3 different maps , full throttle upshifts and autoblip downshifts If you choose , you can also add cruise control if you buy the Tune & Cruise key Wideband o2 sensor, controller HW and fitting kit also available-SOLD Suitable for all Mitsubishi ECU models inc MTS 1200 inc the Twinspark , but NOT DVT , which uses a Bosch ECU Also suits the Diavel and Panigalr range , although will need a different length of bar to suit the gear lever lengths , to fit the QS http://www.tuneboy.com.au/ducati_mitsubishi/ PM if interested
Wideband Kit is now sold QS and the connection HW still available - price £275 All you need then is a Tune key from Tuneboy (£125 at today's fx) and you have a mappable ECU , ExValve elimination, Launch Control and up & down QS for 400 quid !! Plenty of Maps out there to try if you don't want to get it custom mapped - For another 125 quid you could include Cruise control .....
Hi sorry for been a bit thick but is the wide band O2 sensor needed for this kit to work or does that do something else, also could you put a picture of the kit please. Thanks Steve
The sensor is only needed for those that want to map the bike themselves - Others like to load maps that are available online , or simply use the standard map but add the QS or Cruise control - or take to a dyno for a custom tune The kit includes the WB-01 connection along with the cable to laptop and to the bike - plus the strain gauge QS that plugs into the one of the stock o2 sensors - this allows you to change QS settings , switch of service lights, load different maps and other good stuff Can post pics when back in the country next week , but you can see the HW on the Tuneboy link provided Thanks
