Tuneecu Android
Discussion in 'Technical Help' started by chrisw, Mar 17, 2015.
    • Thanks Thanks x 2
  1. Looks very cool!! Gonna try it!
  2. Just been playing with it on the bench. The different functions are reached by sliding the screens left to right (vic\ver). Downloaded one of the .hex files and successfully flashed it to the ECU. There is also immo disable function. I need to see if the Power Commander 3 map overlay works like it does for the Triumph ECU.
    Looks good. I was using it on a TESCO Hudl with a USB KKL lead. Need to test Bluetooth ELM327 to see if that works.
  3. Is it just the same cable that's needed for ducati diag?
  4. Needs to be an FTDI based one as used for Ducatidiag/JPDiag. I need to test whether the BT ELM327 allows reflashing. I will also test if the Winchiphead one works. I'll report back later.
  5. Ok thanks!
  6. Sounds interesting.
    Does this mean I can reprogram my P8ecu with my phone?
  7. No mention of the ST range then.
  8. Only compatible with the IAW5AM ECU
  9. If it uses the IAW5AM the it should work.
  10. If you use a BT ELM327 you only get Diagnostics. For reflashing you need the USB KKL lead (FTDI)
    It is not tied to a single Manufacturer or bike so would be a good investment if you have a Ducati, Triumph, Benelli, KTM or Aprilia
  11. Doesn't work with Winchiphead
  12. Great ! I had TuneECU a while ago for my Triumph 675 via Laptop and VAG KKL lead but this new Android version looks pretty good too (- Ideally I need mapping for my '05 999 with Termi slip on).
    Not quite sure exactly on which map is appropriate for the 999 variants as Map Info / Descriptions fairly vague... I.e. "2219PQ14.hex OEM 999 S. Ducati Performance 57mm full system" is the only detailed one there and nothing extra is listed when you open the maps up in TuneECU App.
    Does anybody have some more info on these maps..?
    Cheers,
    DD
  13. Chrisw, I have a 2012 848 Streetfighter, a 2013 Evo SE corse and a 2014 1199s panigale.
    What leads would I need to do all 3 ?
    What I would like to do is down load the maps from the bike to a laptop as back ups.
  14. Thanks Chrisw. I will try to find the one I need.
    Cupid, the lead type you would need is detailed here: Ducati_Guzzi_Morini_Components
    I have just ordered the Lonelec one.
    Should be same lead for all Ducatis (need to check the models & variants covered in the Ducati Tune list..) No Windows based laptop version of TuneECU for the dukes at present just android...
    Cheers,
    DD
  15. Thanks for the link DD, I have ordered the Lonelec too as that appears to be a complete kit and adaptor cable.
    on the page of the link you have supplied there is links to other sites I am pretty sure there is a windows based app but by another manufacturer.
    Primarily all I want to do is down load my existing maps and save them to my laptop / PC.
  16. If you buy the following then you will be set up for all the bikes and for Android/PC
    GUZZIDIAG JPDIAG DUCATIDIAG KIT - INTERFACE + ADAPTOR [LEZBGUZKIT01] - £19.99 : Lonelec, Fault Code Readers & ECU Diagnostic Equipment
    Ducati 4 Pin Multistrada CAN Diagnostic Connector Adaptor (DDA) [LEDUCC16ADAP] - £14.99 : Lonelec, Fault Code Readers & ECU Diagnostic Equipment
    2015 Mini OBD2 ELM327 V2.1 Bluetooth Car Scanner Android Torque Auto Scan Tool A | eBay
    Software
    IAW5AM - [​IMG]
    You have a choice - JPDiag, Guzzidiag, (Guzzidiag Reader), (Guzzidiag Writer), TuneECU (Android), ScanM5 (Android)
    The only ones giving reader/writer are Guzzidiag and TuneECU.
    M3C - [​IMG]
    Software - JPDiag for M3C
    Diagnostic only, no reader/writer
    Mitsubishi - [​IMG]
    Software - Multi Tool Lite (Android) - you have to sign up to be a Beta Tester to download from Playstore
    Diagnostic only
  17. Thank you foryour help Chris, it is much appreciated.
