1299 Tyre Warmers On The 1299
Discussion in 'Panigale' started by Wull, Apr 3, 2019.
  1. Anyone had issues with clearance between front tyre and mudguard when putting on tyre warmer and removing tyre warmer?
    I have a set of biketek warmers and it seems to catch when removing the warmer, not so much when putting them on. I’m thinking that maybe the abs wiring has a tab that’s positioned in such a way that it catches when removing the warmer.
    The first time I tried it the warmer pretty much came to a stop and was difficult to move any further, second time not quite as bad. I don’t think there’s anything that can break or cause any issues but thought I’d ask.
  2. Mines were tight too, I used Thermal Technologies warmers. Just had to be more careful
  3. I have HWW and they are a bit tight on the front guard but go through ok. Just need to remember to keep turning them over every now and then
  4. Yes i have the same problem the warmers catches the traction wire always think its guna pull the wire out the clip and rub on the tyre and burn through not found a way round it yet other than once the warmers been on and off a bit through out the day they seem to soften up and make sure ther tight to the tyre
