Fitted my full termi system today inbetween torrential downpours. Got it to the stage where I can connect the up-map to upload to the ECU. The bike doesn't even see that the up-map is connected. any ideas?
The up map comes with some exhaust systems. It's loaded through the dashboard. You need a dealer to reload the standard map if you take the system off. Or use TuneECU or JP Diag.
After searching Ducati ms, it says it's dealer only upload. It certainly doesn't work for me so I guess I'll have to wait until Friday for the first service. They also have to sort out my faulty termi exhaust as the bracket that holds the carbon heat shield has been welded on in the wrong place
Early upmaps were plug n play. The new stuff needs to be connected to diagnostics at dealer I'm afraid.
