This sale is for the original performance slipper clutch that was removed from my 1098R at the time of the PDI to be replaced with a titanium spring post DP 'Race' slipper clutch. I wasn't the first owner so don't ask. As can be seen from the photographs, the clutch us in unmarked condition except for some staining on the inside surface of the basket resulting from the over exuberant application of red Loctite on initial assembly. The 'Street' organic friction plates and steels are new but as they were purchased a long time ago, I had to clean the steels. Springs, spring caps, bolts, spider spring, Belville washer, 25mm flanged nut, 20mm flanged nut and DP pressure plate are all included. With the 25mm flanged nut, the clutch fits both 1098 and 1198 and with the 20mm flanged nut, the clutch will fit 9** and 74*. I checked today and although the DP Slipper clutch is no longer available from Ducati, some spare parts still are. Asking £675, including carriage. Andy
I have purchased a 20mm flanged nut for a 748R so this clutch will now fit the 9** and 74* bikes and any Monster that had the same clutch, like the S4RS. I will also include carriage in the asking price. Andy
Bump. I have also updated the original wording to avoid confusion having added the smaller flanged nut later. Andy
Apart from the 8 bolts that secure the basket to the case but you can re-use your existing ones. Andy
