AMy little hands are struggling to apply enough brake pressure on the v4 on track, brake with middle finger. Anyone had similar issue or recommend a solution? Already had a pad upgrade. Cheers
Are you braking with one finger ? If so ,why not get a lever with more off set to bring it closer to the bars ,so you can get at least two fingers round it .
It’s just a comfort thing from years gone by. The lever distance is fine, it’s a pressure issue I think.
Back in the day I had to blip quite aggressively to downshift so more pinkies on the throttle worked for me. Don’t need to blip now but middle finger braking has stuck.
