valve check
Discussion in 'Ducati General Discussion' started by idrinkbeer, Apr 26, 2013.
  1. anyone an idea of cost for a valve check on a 1098s with about 7k miles? oh an I would remove fairing beforehand.
  2. It all depends if they require shimming. I've just had mine checked during some engine work and they were OK. You should be OK too provided you haven't done 7000 miles of racing. I don't recall what the valve check cost was so it can't have been much. I guess you're talking a couple of hours labour so 100 notes tops. Good luck.
  3. Shims are approx 6 quid each so it will be the labour that's the biggest chunk.
    Just had mine done on the Hypermotard by Al at Ducati ProTeam and it was less than £150 including 3 shims.
  4. not to painfull then,many thanks.
