V4 Warning! Monkey Boy Alert...
Discussion in 'Multistrada' started by Bonkers the Dog, Jan 18, 2025 at 4:28 PM.
  1. In case you are unaware...
    If you have a new V4 Multi and you want to remove the off side mirror be advised that they use A FECKIN' LEFT HAND THREAD!!!!
    I only discovered that today as I attempted to replace the mirror and, assuming the recalcitrant bolt was loctited in, went full Gorilla on it and stripped the thread right out of the clamp housing.
    Donkey of the day award to me - cost, Twenty of your Earth pounds.
    You have been warned.
    • WTF WTF x 1
  2. Is that not common, to use a left hand thread
    • Agree Agree x 5
  3. I think most bikes with screw in type mirrors are L/H and R/H threaded.
  4. I've never had one that's not L/H on the right and R/H on the left.
    Prevents the bolts from tightening and stripping the threads when the mirror gets knocked.
    • Agree Agree x 5
  5. And the wind loosening it ...
  6. Then you should have told me lads! Come on....
  7. as said, std practice but irritating, comes under safety regs and not sure how many on a worldwide scale but:
    "object must have compliance wherever possible* when struck from the front of the vehicle" ..or similar..
    *i.e. - in this case, "undo" thread
  8. I guess yours is going to get a right hand helicoil? Stick it to the man and his regulations..
    #9 Petsmith, Jan 19, 2025 at 12:44 PM
  9. agree - i even swapped left for right on one bike as no amount of Loctite* seemed to prevent one mirror arm being "blown" undone.
  10. Oooooh. Helicoil, you just reminded me I have some of them! See me scuttle to my man cave...
  11. In bevel Ducatis, the nut holding the bevel gear onto the camshaft is left hand threaded. Not unknown for the hamfisted to ruin a camshaft ...
  12. Don't left handed nuts have notches cut into them to help identify the thread direction?
  13. Opposing threads for handlebar mirrors is the norm on many bikes, for the reasons already mentioned.
