I need some small (about 3" square) shapes cut from 6mm thick Titanium 6al-4v 10 off Anybody got access to a machine or know a good place to get it done ??
You can do that on laser mate don’t need water jet. Not sure what grade you’ve typed but I can do 5083 or 6082T6 from stock material, if you have dxf drawings I’ll happily cut for you. Most subcon laser cutting companies will charge £150+ min charge....! Edit I’m an idiot, saw al and thought Ali, not titanium! Never dealt with it so can’t help I’m afraid.
Just google water jet cutting near me, plenty of companies offering a service. I have never worked with titanium, Can it be cut on a bench saw? The only reason I used water cut, was for a finished non heated cut. On thick steel and stainless 50mm plus.
A good wire erosion place will be able to do it easily. If you can't find one near you there is a good one called TJ wire erosion in cam,dursley in Gloucester.
