Wax Based Lube (wurth) - Relube Interval And What If It Rains?
Discussion in 'Technical Help' started by dubcat, Aug 10, 2024.
  1. In the cycling world if it rains and you use dry lube (wax-based usually) you need to re-lube the chain as the lube gets washed away quickly. For wet weather, you use an oil-based lube but it gets gunky and picks up crap.
    I've just used wurth wax-based lube. Does the same apply? If it rains does this stuff wash away?
    How often do you relube the chan if using this stuff?
