Weird fault
Discussion in 'Technical Help' started by Paul G, Jul 3, 2013.
  1. I have a new to me 2005 Multistrada 100DS. Virtually every time I go out on it, after a bit, anything from a few hundred yards to 2-3 miles it cuts out.
    Engine management light on, ign light on and no go!
    Stop; fiddle around for an hour or two looking for neutral :biggrin: and then switch off:eek:n: and it restarts and so far its been alright for the rest of the ride. At first I wondered if it had anything to do with the map as it appeared to coincide with the oil temp display going from "LO" to a figure but the last time it happened the oil temp was registering.
    Before I throw my credit cards at the local dealer, does anyone have any suggestions.
    Bike was only serviced and new belts a month ago, although I cant see if that would make any difference, but what do I know.
    Thanks
    P
  2. Can you check to see if any error codes are coming up. Not sure on a multi but will be something like ignition off hold a button on dash turn igniton to on and it will give fault code. Then start from there I suppose.
