What are these fuses for?
Discussion in 'Supersport (1974-2007)' started by YellowDuc, Jun 29, 2013.
  1. Does anyone know what the two fuses are for that are next to each other on the right side of the battery as you sit on the bike.
    They are right next to each other under separate covers and are 5 amp I think.
    I may have a parasitic drain and when I pulled the 5 amp fuse out the voltage dropped? Main fuse box with each fuse out one at a time showed no change.
    Negative cable off and meter set on volts between the battery and the negative cable. It's pulling about 9volts!!!!! Not sure if I'm testing it right mind,
    Got Haynes and bike manual out and can't see what they are for. Hope someone can identify them for me and I can attempt to trace the problem.
    Thanks a lot.
    Mark
  2. Mark,
    To check drain take the positive off and measure amps between battery and positive cable with the ignition off.
    Mike
