I'm just in the process of re-sealing the forks on my '93 750ss. It has Showa forks fitted. Can somebody tell me the correct oil weight for it please. The manual suggests something but I have plenty of putoline HPX10 in the garage and wondered if they are the same weight.
The Owner's Handbook says: Showa S8 (so I guess that means 8) or ATF SAE10W20. The workshop manual says SS8. They also say the 600 & 750 has 7.5 (which is what I use) so I guess 8 is correct. AL
Thanks very much for your help. Seems strange how different manufacturers label their oils differently but at least I now know what should work.
No use for road use. Because the showa forks in class b DD have to be non adjustable i used a mixture of grades to get the rebound slow enough to get the SS to hold a good line. I also used 9.5 linear fork springs. Couldn't afford k tech or maxton cartridges.
Just checked.........I have 10 in my Showas and 7.5 in my Marzocchis.. .......with linear springs in the Showas and cr*p springs in the Marzocchis. AL
