What size socket is it for spark plugs? (1200s)
Discussion in 'Multistrada' started by Steve216, Jan 11, 2014.
  1. I've tried the 10mm spark plug socket but no use!
    also I've take all body work off the tank to reach the vertical plug but I'm still struggling to reach it, do you have to completely remove the tank? If so what's the best way don't fancy fuel everywhere!
    thanks for any advise on this....
    Steve
  2. You may not have to take the tank right off but you'll need to unbolt it and lift the back end and also release the fuel pump connector.
    The plug is 10mm with a 14mm hex: MAR9A-J specifications
  3. OK many thanks I've just checked the front one but can see the difficulties with the vertical one will give it a try now.....
