1200 Pikes Peak Wheels
Discussion in 'Multistrada' started by Podrick, May 8, 2021.
  1. Does anybody know what other model wheels fit a 2016 Multistrada? ie Panigale, 1098, Streetfighter, etc...
    Cheers
  2. I had a ‘15 DVT (now ‘19 1260) and could not find any info on this as well. I bought a set of 1098S forged wheels to see if they would fit, but sadly they didn’t. The front required spacers, which I couldn’t find, and the rear hub size was off. :pensive:
  3. Thanks for the info, hopefully i can cross reference that
  4. The Panigale 1199, 1299 and V4 all have wide track front forks so their front wheels are not compatible with the 1200 Multistrada. The Multistrada has a big bore rear axle so you can use the Panigale 1199, 1299 and V4 rear wheel. Contrary to what mikeyyah found, I have 1098R wheels on my 1200 Multistrada and I also have a pair of wheels from a Hypermotard 950SP. My Hyper wheels are identical in spoke style to the 1299S wheels I have on my V4 so you could mix and match if you could find individual wheels. Andy
  5. ^ What he said.
    BST list 1098 and MTS as same model.
