Where And How Have You Fitted You're Gopro?
Discussion in 'Clothing, Gadgets & Equipment' started by timberwolf, Aug 5, 2016.
  1. Just pondering. I purchased a GoPro alike a couple of months back with lots of fittings but can't work out where to fit it to the bike. I realise some fit them behind the screen but having a dark smoke screen that's out. On my previous gixxer I fitted a camera to the offside fairing about half way down but am loathed to stick the 3m pad on the expensive ducati fairing.
    Anyone fitted theirs on anything else? I don't want to stick the 3m pad on my new lid either.
  2. Just ride like a twat and turn yourself in to the local police station at the end of it. Cut out the "middle man" so to speak :)
  3. I have an edible micro sd card :Mooning:
  4. No need for any fancy brackets.
  5. Thanks guys, trouble is I have a dark smoked screen. Do the 3M adhesive pads come off without damaging the paintwork ?
  6. Little bit of heat from a hair drier will help bring them off no problem.
  7. I havent got, used or tried any of these, but they are cheap enough to bin if they dont work....
    Bar Mount Adapter Bike Motorcycle Handlebar Aluminum for GoPro Go Pro Hero 1 2 3 | eBay
    Bike Motorcycle Handlebar Mount Bracket Holder For Gopro Hero 4 3+ 3 2 1 Go Pro | eBay
    Bike Bicycle/Motorcycle Handlebar Handle Bar Camera Mount+Tripod Adapter For Gopro Hero 4S/4/3+/3/2/1 For Xiaomi Yi Gitup Git2 -in Camera/Video Bags from Consumer Electronics on Aliexpress.com | Alibaba Group
    Hope this helps
    Btw, if you do get and try any of the above, let us know how you get on, they when I eventually get a cam I will know what works !!
    stuart
  8. I have this and so far it's been fine. No one tells you to push the sucker down first then push the clamp.
    Been fine at all legal speeds *cough*
  9. Looking at this one, could it perhaps be fitted/sucked onto a screen, I have a Diavel with a relatively flat (ish) screen so that looks ideal.
    stuart
  10. I think it would definitely need to be quite flat. Once it's on, it's like a limpet. Some people reviewed it on Amazon and said it fell off. I think they've tried round panels or not put it on properly.
    One thing about putting it on your fairing is that they of course vibrate a bit especially on bumpy roads. Tank is better if you can.
    Cheers. G
    • Thanks Thanks x 2
  11. Was the writing on the button that says "press" not enough of a clue?
  12. I'm an average guy, I don't read instructions.....
    It should have said "press harder".
  13. But you wouldn't have read that either
  14. Instructions.......please explain???
  15. I didn't, until someone pointed it out....
  16. I can't...you'd need instructions and then it would be like looking into opposing mirrors.....
  17. I lost one of the GoPro sucker mounts off of the (very slab/flat sided) door of Dodge Challenger. I would very definitely utilise some sort of tether if using one of them.
