Which front brake discs from other model Ducatis fit the Multi 1200? I'd of thought the 1198 would but I've contacted a couple of sellers and they tell me not. Surely the Multi isn't a special sized disc? Also do we think its worth while having a sticky that's updated to show this kind of thing? In other words a 'which parts fit' section as there must be loads more parts available to fit the Multi that aren't public knowledge or without sifting through 1000's of posts?
I think it might be, I'm afraid. Pretty sure the MTS disc is 320mm, as opposed to the 1x98 330mm. 848 non-Evo discs are 320, but no idea if wheel fitment/offset is compatible.
I reckon most modern 320mm Ducati discs will fit. Aren't they nearly all 15mm offset now? All 5 bolt pattern. So that would included the 749/999, 848, Hyper, probably the Monster and Diavel too! Just a guess
Why not just do a trawl of somewhere like the brembo catalogue ? That would give you the part number of the MTS discs, and also all the other bikes in the Ducati range. Just a thought
