V4 Will A 2018 Bellypan Fit 2020 Upper Fairings?
Discussion in 'Panigale' started by JimboV4, Aug 15, 2023.
  1. I’m thinking of buying race fairings but keeping lower belly pan if the fitment is the same.
    many guidance would be appreciated
    Thanks
  2. Which 'race' fairings are you looking at? Typically there are fitment issues between the two as the bolt locations have changed slightly as have a few other bits.
    You can get them to fit but it will need modifying.
  3. Thanks
    I’m looking at the oem race fairings
  4. Okay, so the Ducati Performance fairings? If so they might be a little more complicated as they are just the original fairings but unpainted, so they are a little difficult to 'adjust'
  5. I bought a set and they are a straight fit with perfect alignment
  6. Ah, that’s interesting. The set I had didn’t fit. Good to know
