Will race Termi's fit a Akro Evo Ti headers/mid pipe?
Discussion in 'Ducati General Discussion' started by Chillo, Oct 12, 2013.
  1. Will race Termi's fit a Akro Evo Ti headers/mid pipe? Or will just Akro cans fit?
  2. with a big enough hammer............im guessing an 1198 and the answer is no, unless you put some work in then anything will fit anything!
  3. lol
    sorry yeah 1198!
    i take it different dia etc
    With the Termi 70mm full system does it use specific cans or is the fitment of Termi cans universal to that and the standard headers/mid pipe?
  4. you can get several combinations what have you got and what are you looking at might be a start.......std pipes id probably get rid of the flapper valve, and then get open cans with the correct link pipe.....getting the fuelling sorted properly afterwards, full system Akra or termi, easy peasy (1198 and 1098 are different) and id get the fuelling done properly afterwards ie not just a cpu swap!
  5. Just bought some 'slash' cut Termi's off the bay that where on a 2010 1198s so thinking the ecu will be ok for now.
    whats the best way of getting the flap sorted? Seen the valve bypass part on eBay is that any good?
  6. Disable it in ECU, together with Lambdas
  7. Ok ta!
    any recommendations on where I can get this done?
  8. cjs when he does your fuelling :wink:
  9. chrisw is your man.
