Xdiavel Radiator Assy
Discussion in 'Ducati General Discussion' started by Alan Blake, Nov 11, 2023.
  1. Morning all,is the radiator assy supposed to be fixed to the bike on the rhs,the fisch shows no fastenings on the right,just for the lhs and top.Strange thing is that there is the rubber and sleeve fitted to the assembly
    Sorry for a stupid question.....
  2. In short, no.
    Usually the RHS has a rubber grommet in a bracket on the radiator which simply sits on a spigot protruding from the frame. The LHS has a bolt that goes through a similar rubber grommet and screws into the frame.
    To remove undo the bolt on the LHS and the LH side of the rad drops slightly allowing you to push the rad to the RHS and off the spigot. Assembly is the reverse.
  3. Brilliant, really appreciate your help with this as I couldn't work it out,
  4. When reassembling it put a little red rubber grease on the rubber grommets, it helps them slide on (and off next time) easier.
  5. Thanks for your help
