Xdiavel Won't Start (no Spark)
Discussion in 'Technical Help' started by flutter, May 10, 2024.
  1. Hi all! The motorcycle sat in the garage for a week while it was cold outside (down to -4). A week later I tried to start it, but the battery did not provide enough power to start it. I charged it the next day, installed it in the motorcycle and tried to start it. It started hard, but it started. After a minute I turned it off and screwed the plastic back into place. I tried to start it again, the starter turns the engine, but it doesn’t start. I also bought a new battery, but it still didn't help. The motorcycle has been in service for a month now, we tried to change the ECU, crankshaft position sensor, relay, but there is no spark at the spark plugs in any case. The fuel pump pumps perfectly, the injectors inject fuel. I don't know what else to check anymore.
    https://youtube.com/shorts/BQP6eXW1nH4
