For Sale Yamaha R1 98 4xv
Discussion in 'Other Bikes For Sale' started by carson, Oct 12, 2019.
  1. Genuine 1998 white/red bike as recorded on the V5 with no colour changes.
    The bike has covered 47k miles and had an engine refresh 1500 miles ago all documented.
    As well as the engine refresh 1500 miles ago the following was carried out:
    New wheel bearings and seals
    Head bearings and seals
    Swingarm bearings and seals
    Suspension linkage bearings and seals
    All fairing fasteners replaced using genuine Yamaha items.
    Carbs refurbed
    New genuine Yamaha throttle housing
    New genuine Yamaha brake fluid reservoirs.
    New genuine gear shift boots
    New genuine Yamaha front sprocket cover
    New genuine Yamaha grips
    Exup valve overhauled
    Front and rear brake calipers overhauled with new seals and brake pads
    New battery
    Genuine Yamaha rear reflector and bracket (be wary of fakes as people are now producing these on their own as they’re becoming so scarce and expensive)
    Full uncut, undamaged undertray
    Brand new genuine Yamaha front mudguard
    In addition to the standard refurb parts, the bike has had the following:
    Ohlins road and track forks (becoming rare on their own), fully serviced. Full forks not cartridges.
    Ohlins rear shock, fully serviced
    New Akrapovic exhaust can (again becoming rare)
    K&N air filter
    White powder coated wheels
    New HEL braided brake lines front and rear
    Bike was set up on the dyno and produced 139.8hp at the rear wheel with print out to prove (they only made 132 at the rear wheel new)
    New coolant, oil and filter
    The original exhaust, forks and black wheels with discs including new Metzeler M7RR tyres are also included at this price. Bike also has full original Yamaha tool kit.
    Bike has an MOT until April 2020 and needs nothing.
    There’s receipts for thousands with this bike and as such I’d recommend viewing as I’ve probably missed loads that’s been done but you can see that there’s been no expense spared.
    I can provide photos of the engine rebuild etc.
    £8500 with all of the original parts including forks, shock, exhaust and original black wheels.
    Can do it cheaper if the original parts are fitted.
  2. Damn I'd love that!
    Good luck with the sale.
