Hi guys first time user 1098s has an intermittent fault under 5500rpm Iv'e looked at downloading the JP Ducati software where do I find the ECU info to register with JP I thought i'd start by resetting the TPS
I use the Guzzi version - much the same. Good tutorial here. GuzziDiag HowTo - A tutorial for beginners
You need the leads connected to the diagnostic port and JPDiag running to read the ECU serial number from which the licence is generated.
Thanks guys Got JPDIAG initial setup to operate Send the ECU serial #, etc. Still waiting on the unlock key Never mind Fault has cleared I'm thinking it was just bad fuel Thrashed it over the weekend. Didn't miss a beat
