Hi Everyone, I'll try and explain! I have recently renewed the clutch on my 996. After reassembly the clutch didn't work, Some time later after a bit of research I discovered that my Oberon slave cylinder has a spacer inside it. This is now missing. I am pretty sure the pushrod that goes through the centre of the main shaft goes from one side of the engine to the other, so no chance of it being inside the engine?? It must be on the floor in my garage ( I hope). I would appreciate if anyone can ease my mind before I find out the hard way. Cheers, Paul.
Ps, the shaft can pull out either way, you should be able to push it through from one side to the other.
