1200 More Power?
Discussion in 'Multistrada' started by Tigerstrada, Jan 4, 2017.
  1. Tigerstrada Italy
    Tigerstrada Member
    Dec 8, 2016
    37
    3
    8
    south wales
    Ride:
    2010 ducati multistrada 1200 s touring
    So I know the multi 1200 is a restricted 1198 engine
    How is it restricted, has anyone derestricted it and if so how?
  2. Majvs United Kingdom
    Majvs Active Member
    Jun 9, 2012
    363
    69
    168
    Manchester
    Ride:
    Ducati Multistrada 1200S Touring
    Short of expensive major engine work the best you can hope for is to let the engine realise it's potential power. Cheapest way to do this is to bin the standard exhaust and fit a decent decat system. Then I suggest you have the ECU reprogrammed to clean up the running. These two mods will automatically release more power ( mine rose from 143 to 151hp at the back wheel) and beef up the mid range. If you need any more than this in your Multi then you probably need a different bike!
  3. Tigerstrada Italy
    Tigerstrada Member
    Dec 8, 2016
    37
    3
    8
    south wales
    Ride:
    I've got a decat pipe and a mivv end can on it
    I was just curious as to how it was restricted more than anything, I've had bikes that have been restricted versions of something else and it's usually easy to do
  4. bradders
    bradders Elite Member
    Apr 19, 2012
    23,124
    4,914
    483
    Gloucester
    Ride:
    '13 Numpty, gixer faaasand track bike
    Think its the motor rather than just mapping, probably airbox too. No idea if an 1198 sbk engine would drop in tho... @Nelson may have an idea as he has just put a multi in a 916 and had done that before with a 1098
  5. Nelson
    Nelson Elite Member
    Apr 19, 2012
    7,425
    2,282
    443
    Swindon
    Ride:
    748/1098 Bitsa..:)
    Think de-tuned rather than restricted.
    Unfortunately there's no convenient valve or bung that can be pulled to produce more power.
    Lower compression, different valve overlap timing, less harsh cams....Blah de blah blah.
  6. Pete1950
    Pete1950 Elite Member
    Subscriber
    Apr 27, 2012
    10,235
    3,842
    473
    London E6
    The main difference from the 1198 (in the pre-DVT Multistrada) is that the valve timing has been changed, with the overlap reduced to 11 degrees. This makes the engine smooth and tractable at low revs, at the cost of some reduction in power at the top end. Fuel injection and ignition maps etc are obviously tuned to suit.
    In the case of the DVT Multistrada, valve overlap is variable thus giving the best of both worlds.
    Since Ducati went to a great deal of trouble, expense, and complication to achieve all this for the Multistrada, it would be amazingly perverse now to go to a lot more trouble, expense, and complication to reverse the process and end up with an 1198 superbike engine - which was the starting point.
  7. Tigerstrada Italy
    Tigerstrada Member
    Dec 8, 2016
    37
    3
    8
    south wales
    Ride:
    That's
    That's the answer is was looking for, knew someone would know
    I've had bikes with restricted/detuned versions of another engine and it can be easy to get the power back up.
    But yea, ducati have basically made it impossible
    Thank you for that answer
  8. jcmental
    jcmental Well-Known Member
    Apr 23, 2012
    895
    175
    303
    Walney Island
    Ride:
    Multi S GT or the wife if it's raining.
    Not that impossible, surly all they did to alter the valve timing was re profile the cam lobes from the 1198. may be get a set of 1198 camshafts? It might be as easy as that, if it is then whats to stop you getting a high performance set of cams off a race version of the 1198. a new engine map and hey ho the front wheel would become even more redundant than it is now on the mutly.
    #8 jcmental, Jan 12, 2017
  9. paulfastbikes United Kingdom
    paulfastbikes Well-Known Member
    Apr 19, 2012
    962
    220
    193
    south London
    Ride:
    Ducati multistrada ds 1000
    get a panigale and bin the clip ons fit hi handlebars and away you go ;.0
Loading...
Share This Page
