New To The Forum, Need Advice On Next Bike!
Discussion in 'Newbies Hangout' started by Tmac88, Apr 17, 2017.
  1. Hey new to the forum and looking to get a ducati soon.
    I'm 29 from Aberdeen, haven't been riding that long maybe 3-4 years on and off. I started with a Yamaha FZR400RR, Ducati Monster 1200 and just sold my MV Agusta F3 800 last year due to being made redundant.
    So I'm looking at either a 749S or a 848. Would prefer the 848 but it is quite tall I'm only about 5'4" so dunno if it'll be a struggle.
    The 749 however seems to be a lot lower so it might be better starting on that and working up the 848. I don't fancy lowering the bike and I already have the Daytona boots that gives me about an inch.
    I've read a lot about the 848 really benefits from getting the suspension set to rider, would this lower it slightly if you got the right sag?
    I know the best thing would be to try them but there isn't any close by for sale at the moment.
  2. I know @El Toro always has to stand at the front when photo's are being taken and he has had a 848, perhaps he will shed some light on height. :smiley:
    Steve
  3. Welcome Tarmac :upyeah:
    Do you know Rod the obnoxious? He lives up your way and has a 749S and a white Harley. He's been quiet of late but he'd have given you a look see at his :)
  4. Yeah,but what about his bike?.........Hi by the way.
  5. Not sure why @Chris tagged me on this...probably because I am a short arse who owns a 749 and a 1098.
    I do not have any probs with either the 749 or 1098 (which is the same geometry as an 848) with regards to seat height. I would say they are approximately the same height. Once riding, there iare certainly no issues at all.
    The 749 is definitely not "a lot lower".
  6. Hello and welcome:upyeah:
  7. That's surprising to hear, going by stats the 749 has a 790mm seat height and the 848 is 830mm. I believe the 1098 is 820mm at it's lowest setting.
    Obviously the specs aren't what to go by but that's all I can go by till I get to plonk my short arse on one!
  8. I will get my tape measure out and report back.
  9. Hello and welcome into the mad house
    @chizel how do you get on with height wise
    Probably ET is the best one to answer height questions the little bundle of joy :)
  10. Get a red one.
    Best colour and fastest.
  11. You took the words right out of my mouth AC :)
  12. not ridden an 848. My 749 I found quite tall but it wasn't set up right for me as my mates one is a bit lower and easier to dismount and maneuver.
    Something I was going to do was tap a lil bolt into the stand so I could hook it down first as I'm more comfortable getting off a bike like that. I'm 5'6 and the bike over all was a good fit.
  13. Hurry up...
  14. I'm 5'6" but I had to have my 848 lowered to make it comfortable when at a standstill. From memory they were able to lower it around 50mm.
    No such luck with my 899 & 959 as the suspension doesn't accommodate such movement.
    Anyway welcome Dave.
  15.
  16. No issues at all from it being lowered. Though moving from an IL4 to a Ducati meant I had to recalibrate my brain and wrists to ride a much more focused machine (read more aggressive head down, arse up stance). Took about three weeks to do that, then all was good.
    In fact all was excellent :)
  17. I did read some where that the 749 can be lowered more by fitting a 748 ride height adjuster but I don't know how true that is.
    personally I think you should get an 848
  18. Hello & welcome
  19. Here's the numbers. Sorry about the delay.
    Both measured on paddock stands with wheel centre 38cm from floor.
    Measurement 1 taken from centreline of seat, across seat and vertical to floor
    Measurement 2 taken as vertical height of seat from floor
    1098: 1 = 94cm. 2= 85cm
    749: 1 = 96cm. 2 = 87cm
    Conclusion: 749 > 1098
    It's an oxymoron. Discuss.
