Hi guys! I have a question. I can not find the correct information in network. It has the basic version 1198 2011 Quick shifter and DTC?
Not too sure on the question friend but the qs only came as standard on the SP model (and R i believe), the base and S don't have one.
IIRC 1198 base - no DTC or QS 1198 S - DTC only 1198 SP - both 1198 R - both and a whole lot more! but I could be thinking of 1098
i got a feeling the later 11 plate 1198 base did have a qs and dtc, ducati aylesbury had one for sale .
May be they did, Ducati have a habit and sticking additional parts on end of line just to empty the bins
You learn something new everyday. Mine is a 2010 S and doesn't have the QS, so maybe they did spec them out later on.
I think that when they did the last run of the 1198 they threw all the leftovers at it which is great for base model owners
Its an easy enough upgrade if you don't have one. My 1198s didn't have one, I bought an OEM off ebay and flashed the ecu to activate it.
To add - I had a 2011 1198. That last year of the 1198, DTC and QS both came on the base model. The 1198S had it earlier. 2011 only the 1198 SP was available next to 1198. I had both the DTC and the QS switched off as both were shockingly bad. Annoyingly, the QS, automatically switches back on when you turn the ignition off and back on.
