hi guys recently had my bike mapped by cjs and he used the 1198sp softwear so ive now got the ability to run traction control on my bike, question is is it worth it?? ive had no problems with not having tc so far, so is it worth the expense of all the hard wear?? cheers
My TC is lit up all the time when I'm racing. Not sure about the value to regular street riding. You'll need to change the rotor and do some wiring along with the ECU flash to get it working. Couldn't hurt in wet weather. The cost to install compared to the cost of bodywork and damaged bits would pay off. If you only ride in the sunshine it might not be worth it.
If you have DTC and find it a bit abrupt then you can get a TC Pod which allows you to change the level on the fly, something you can't do with the standard DTC. Ducati DTC TC-Pod Sent from my iPad using Tapatalk
