1098 1098r And Bayliss Owners Advice Needed
Discussion in '848 / 1098 / 1198' started by ducatidude1098r, Oct 22, 2015.
  1. How is the fit of your Corse fibreglass ? Not heard particularly good things about it. Andy
  2. Sorry, I don't really understand the question.
  3. OK, off the top of my head...
    Engine
    Pistal HC pistons, Waterless coolant, JHP air filter, lightened flywheel, Samco silicon hoses. JHP superstock ECU.
    Gearbox & Clutch
    Nova race gearbox, Nemesis quick shifter c/w reverse race shift, JHP clutch cover, DP pressure plate, JHP clutch slave cylinder
    Exhaust
    72mm Termignoni slash cut system
    Suspension
    Ohlins front 30mm internal cartridge kit. Standard TTX rear.
    Wheels
    BST Carbon jobbies
    Controls
    Gilles VCR rear sets, Gilles X-Treme GT2 brake & clutch levers, Quick action throttle.
    Bodywork
    Race screen, Superpole seat, carbon hugger & various small bits of carbon, Quick release fuel filler cap.
    Traction Control
    Nemesis traction control
    Electrical
    18A Shorai lithium battery, Exact start starter lead kit.
    Probably some more that I've forgotten about.
    #23 Robarano, Feb 6, 2016
  4. Does it fit to the bike like an Italian hand made suit, or a Russian off the peg one? :)
    #24 Robarano, Feb 6, 2016
  5. In conversation today, I as told that the individual panels did not fit together particularly well. Joint lines were irregular and at least 2 of the fixing holes didn't line up. So basically crap unless your feedback puts a different light on it. Andy
  6. So not much then ? What do you reckon on the comfort of the superpole seat ? Thanks, Andy
  7. Essential for me Andy. I'm 6'1" and used to find my 1098S uncomfortable to ride before I put the Superpole seat on it, regularly getting leg pain. It's only about an inch taller, but makes all the difference for me.
    Another benefit is that you stay absolutley planted to the seat, wherever you put your backside, that's where it stays. No more sliding up to the tank when braking and a lot less gripping the bike with your knees to stop moving around. I highly recommend them.
    #27 Robarano, Feb 6, 2016
  8. Sorry Andy, I only went on my (failing) memory just to start the ball rolling. Hope you find one soon.
  9. Not a problem Chris, keeping my fingers crossed. Andy
  10. Oh. I see :-/ My experience of fairing fit - ranging from OEM Ducati stuff to various aftermarket track plastic is that the Corse fibreglass is at the better end of the spectrum. The sides and belly pan are all fixed with dzus fasteners and they go on and off real quick.
    Slash cut end cans. I have always liked them more than the originals. Never been able to justify the expense. That's plenty tyres :p
  11. Totally agree, (from a mere 848 point of view). Their carbon fibre stuff in most cases fitted better than the OEM plastics. A bit light on the lacquer but good none the less.
  12. Yes. I have joined the R gang.
  13. sorry i'm late, another '1098R' owner here.
  14. And as of 5 o'clock this afternoon, after months of searching and failing miserably to secure a deal, so am I. All happened literally in hours after a chance meeting in the parts department at Moto Rapido. Andy
  15. Well, hoisted by your own petard........What has it had done to it? and get some pictures up!
  16. It's currently having a belt service and valve clearance check at MRs and if you have a look at the thread "pictures of a naked lady" there are a few of the bike without her clothes. The only significant modification is the 70mm exhaust with slash cut cans. Except for some short levers, DP Corse race change rear sets and a quick release petrol cap, she's bog standard. Registered in March 2008, 6600 miles and 1 owner. Andy
    Edit : Had a better look now and all standard except for a 70mm Termignoni system with carbon slash cut cans, DP Superpole seat, DP quick action throttle, Renthal folding levers, DP rear sets (race change), DP q/r petrol cap, Renthal q/r rear sprocket, DP carbon swing arm cover and DP carbon heel plates. Not sure if the small carbon hugger is std or not. A
    #39 Android853sp, Feb 11, 2016
  17. Dunno why, but it feels cathartic writing this... but there is no other bike that delivers a hit and rush like this. Properly keeps me alive.
    Engine
    Polished heads, HC Pistals, Corse throttle bodies, Corse velocity stacks, balanced crank, Samco hoses and thermostat, DP air filter, ceramic coated 70mm system, slash cut Termis, custom map
    Drivetrain
    Superfinished gearbox, Oberon clutch slave cylinder, stainless clutch springs, DP pressure plate, Renthal QR carrier, RR520 chain and sprockets, GIPro gear indicator
    Suspension
    KTech 20SSK, correct weight Ohlins springs front/rear, 5wt oil
    Electrical
    Shorai LiPoFe battery, Exact starter cables, 3 x 2A USB, integrated mic for recording
    Controls and Ergonomics
    Corse RS rearsets, integrated HM reverse QS, Accossato QAT, Helibars, Rizoma levers, Superpole seat, DP mirror extenders, DP clear double bubble
    Bodywork and Misc
    DP aluminium tank, DP Tecno clutch cover, Panigale indicators, DP carbon hugger and panels, Rizoma fluid pots and QR tank cap, titanium bolts all round, R&G under panel frame and fork sliders, RAM mount, Brembo SC pads, Motul 300v, custom painted wheels, Ventureshield
