1198 1098r Rebuild
Discussion in '848 / 1098 / 1198' started by Spareparts, Apr 30, 2014.
  1. I had a 996BP previous.But the 916sps I have is a different animal entirely.Much more aggressive power delivery.A touch less right down low but from midrange onwards its absolutely nuts.The sound is a lot different also more raw.
    I guess this is exactly the same between 1098 base/1198 and a 1098R/1198R corse edition.
  2. An SPS will lift the front on the throttle in 4th, mine would, used to scare me the smash in the face delivery. Not ridden a 1098 yet...suspect I'd want one if I did!
  3. Nay nay lad. Dunno exactly what mine weighs but deffo significantly less than 185.
  4. 173 dry, 195 wet ;)
  5. It's lost just over 5kg with the Ducati ally tank, lithium battery, and variety of DP carbon parts. Standard weight is 165kg.
  6. Well mines less than that. Mind you I've just had 6kg's of metal lumps fall out during an oil change.... Bah ha ha ha ha ha ha.... etc...
  7. That wiki link shows 1098R as being 165 dry.
  8. Lol i must be blind :) still be a good 185 with fluids lol
  9. Yeah yeah see above ;)
  10. Wet/dry, doesn't matter. Losing 5kg on the machine is still minus 5kg
  11. Yep, takes it down to 190 :upyeah:
  12. So when you buying one ;)
  13. When I can afford to run one pmsl
  14. Good man! It's 159kg dry weight then. My ample ballast needs all the help it can get :)
  15. Have you weighed it?
    They were meant to have 180bhp but that was found not to be the case
  16. JHP have told me that with a bit of improvement the figures these 1098R bike put out is scary and well above 180.
    I think the key regardless of a few +/- bhp is in reality does it scare you shitless.If the answer is yes then its a bike I would like to own (if I can afford the running costs).One of the reasons ive held onto the sps for so long.
    I can confirm bradders is right.Since I had the valve collets replaced on last service the bike has a nack of lifting the front when you don't expect it at a alarming rate.Even with a longer swingarm lol.
    #80 matt#corse, May 2, 2014
