1199 1199 Race Seat Or Comfort Seat
Discussion in 'Panigale' started by JAM35, May 10, 2015.
  1. 5'10"
  2. hair and eye colour? in fact any pics?
  3. as requested :)
  4. Same height as me then, are you 50/50 body and legs length or are you short bodied, the reason I ask is because it all has a bearing on your seating and reach position on the bike..
    I find my 848 Evo comfortable, my 899 was comfortable but I cannot for the life of me get comfortable on the 1199 :(
  5. its seat is too high, try the original one, you'll be comfy!
  6. Nope I tried that, but suspension is so stiff even on its softest setting it bounces me all over the place, and yes its set to P not F
    Got an 80nm spring on order will see what's what when thats fitted and suspension setup all over again.
  7. I would advise 1299 is lovely over the standard seat, like sitting on memory foam. :upyeah:
  8. Is there a lot of ass to remember then :)
  9. lol, try this.
    I run tyres at 30psi fr and 34 rear.
    You need to get some sag, remove some preload on the rear, one full turn is about right.
    Try these settings, save them in your Sport mode.
    You can mirror the settings to your race setting, and alter the values by 2 (either way) then toggle between the two to find the best ride.
    Just remember to change the race display to road on your race setting.
    Front Compression - 28
    Front Rebound - 13
    Rear Compression - 28
    Rear Rebound - 13
  10. Here are my current settings
    Static Sag Front 28
    Static Sag Rear 17
    Rider Sag Front 39
    Rider Sag Rear 32
    Spring rating 90nm
    Front Compression - 20
    Front Rebound - 15
    Rear Rebound - 23
  11. Thanks for the settings, out of curiosity what do you weigh in at approx with al the kit on leathers boots and lid ?
  12. yeahhhh, your pretty soft already! what is your weight pls? (sorry if you have posted this already, but im lazy today)
  13. 13st or 83kg with bacon butties and tea in ma belly!
  14. At a oush /I am 11 n half stone in full leathers but can be known to drop to 11 stone in full kit.
  15. you skinny stunt, you need an 80mn spring! :)
  16. Ha ha I know that stupid fish hence why I said in an earlier post I have ordered an 80nm spring. It should be fitted by the end of the week
  17. i know i was being sarcastic o_O
    let us know how the new spring goes :upyeah:
