1299 1299s Underseat Exhaust
Discussion in 'Panigale' started by AndyJPerks, May 10, 2023.
  1. need a bit more help on this , I have fitted a tail tidy and aftermarket indicators which worked then I assume blew a fuse
    I have lost my manual, what fuse is it for the rear indicators for the 1299 please ?
  2. Owner’s manual can be found here, https://www.ducati.com/gb/en/service-maintenance/owner-manuals Andy
  3. Yes the T800, seems to work well, easy to switch between maps for baffles in or out. Obviously not as good a as bespoke set up, but being able to swap maps is useful
  4. what is the difference between the D170 and the D171? Are the silencers different lengths?
  5. #26 Nathanhu, Sep 16, 2023
  6. Thanks @Nathanhu - This is to go on my race bike so no fans to worry about - what are the length of the cans on your system?
  7. I think mine are 450mm for the sound restrictions on Eu tracks i use..
    But Phil Smith can tailor to your needs in regard to length and also diameter.
    i think the reparto d171 is 60mm and the D170 is 57mm but its been a while since I had these cans made up
