1998 748 Rebuild *pic Heavy
Discussion in 'Builds & Projects' started by Jamiej, Mar 16, 2015.
  1. Tony,
    As great as that would be, I wouldn't want to put that burden on you!... Yet!
    Your comments already helpful. I go though and see what i can match with what. There is a good chance that those bolts include some engine bolts.
  2. Are we identifying every part in your pictures.
    Steve
  3. Well any that are obvious would be a great help! May also be useful for some other fool who had all their bolts plated and mixed up!
  4. If you PM me with larger photos I can at least identify the more obvious ones by number. You have both engine mounting bolts and what looks like the nuts for example and also the lower shock mount bolt and "nut" so that eliminate some already.
    The real problem is the odd shaped ones that have small heads compared to stock thread size, there are not many but really it needs to be right. You have my offer so feel free to use it and don't feel reluctant, we are here to help each other are we not?. There is no point in a forum if no one will help?
    It may be easier to say "what bolt do you think fits this (part)! and then at least I can give you an idea, give it a try.
    39 (or 38) looks like the rear axle pinch bolts by the way.
  5. No 40 engine mounting bolts
    39 look like swing arm eccentric pinch bolts
    37 could be bottom fork pinch bolts
    above the board is front axle and above that is the swing arm pivot bolt.
  6. 19 is rear of tank fixing bolt
    20 look like air box fixing bolts
    9 looks like it mates up with spring no 6 which adjust the headlight.
  7. assorted brackets are for your seat and rear light also one for the headlight bucket to head-stock mounting and of course the rear axle.
  8. 34 loos like the nut to go in the swing arm pivot bolt.
    21 could be footrest heal guard mounting bolts.
    I will keep looking but as Red 998 says they will have to be matched and I don't want to guess to much and mislead you.
    Steve
    #48 Birdie, Apr 4, 2015
  9. Brill, thanks all.
  10. 36 looks like the lower shock bolt
  11. 36 looks like the rear bottom shock mounting bolt.
    spring no 2 fits on your seat hinge
    possibly two of the nuts from no 1 fit your engine mounting bolts no 40.
    Chizel beat me to it.
    #51 Birdie, Apr 4, 2015
  12. sorry birdie that was an easy one:) 2 looks like rear brake lever return spring and bolts 10 airbox i think
  13. the long ones obviously engine mount
  14. Mine is a 1998 as is this one and mine doesn't have a rear brake lever return spring, mine could be wrong!! 10 airbox?
  15. mines a 99 and does have a spring you can just see it in this pic
    the other bolts look like airbox ones (i dont mean 10 of i mean number 10) but i could be wrong and often am
  16. you can also see were number 3 goes in this pic (just below oil sight glass) the one to the right of no14 (cant read number) looks to be either rear brake or gear lever pivot bolt but that would be self explanatory when fitting
  17. just thought the other spring is head light adjustment one
  18. Do you only look at pictures without reading previous posts.
    Can't get smilies up on the mobile so wink wink.
    Steve
    • Disagree Disagree x 1
  19. yea six is headlight spring im sure. when i said 10 for airbox i think i meant 20 as in in one pic they are to the right of ten and in another they are below 20 but there is 4 of and from memory there is 4 the same and an odd one
  20. sorry... i have terrible short term memory and also dont see all that i am reading... was i right? thats the main thing!!!
