That’s the plan mate. No idea how it’s got so hot! I changed all of the plugs out when I had the bike apart as well. Hopefully I’ll be able to pick up a new reg/rec from ProTwins and get back on the road again
Have you got a Mosfet one on, Tel? I picked a Diavel / Panigale one up cheap off eBay and not had any problems with it.
I’ve just got a bog standard one on at the moment mate. Pain in the arse is that I was relying on using then bike this week for work. I’ll see if I can get hold of a Mosfet one with plugs
Is it the reg/rec that has caused the overheating of the plug or a loose connection, the reg/rec might be ok, if it was the reg/rec, was it overcharging to cause the heated plug, if it was not charging how did it overheat the plug. Just thinking out aloud. Steve
