2013 848 Evo 1040 Big Bore Kit
Discussion in 'Newbies Hangout' started by 1040, Mar 28, 2015.
  1. Pretty sure the rear on the 848 has a smaller hub size; thought the front was the same but might be wrong... 848 has 320mm front disks... Cheers, Bob
  2. Also, EVO had mono block front callipers as standard so pretty good spec...
    Bob
  3. Later (LE I think) 848 went to 330 discs same as 1098, 5mm spacer under the calipers required.
    848 rear hub size is same size as the old 916, but smaller than 1098.
  4. 2013 848Evo corse se thingy V inlet cam 14823471C
    V exhaust cam 14823491C
    2011 1198 V inlet cam 14823391A
    V exhaust cam 14823411A
    2011 1198 Sp V inlet cam 14823391A
    just saying...............
  5. The Evo has has 245mm rear discs fronts at 320mm, the rears are same diameter as the 1098.
    The Brembo Monobloc are the same as the 1198 4 x34mm pistons so I think she should
    pull up alright. I think the Evo is also lighter we should help.
  6. Looks all good ta for the info, now how much to upgrade my 848 Evo and Streetfighter to 1098 :)
  7. Thanks for the consideration but going for the BST carbon wheels after the engine upgrade.
  8. Cant imagine any issue whatsoever with the brakes, 848 are way better than my gixers ones and that has loads more power
  9. Good pick up I did a bit of digging on this and you are correct they are not the same,
    but share the same valve lift is what they should have stated.Inlet 13mm/Ex 11.5 wild
    cams I wonder on the longevity?
