1200 2015 Bike Launched
Discussion in 'Multistrada' started by Speed_Triple, Nov 4, 2014.
  1. Thats very different to mine john. Ok I have only done a few hundred in single digit, maybe a thousand or so, miles but always returned roughly the same results. My bike runs around 70 (outside of heavy traffic) all the time
  2. It's your thermostat that controls engine temp, the radiator just cools the coolant after the thermostat opens, so get your thermostat checked.
  3. Dave, your sort of right.
    Problem is, if the radiator over cools, the thermostat will not open fully.
    My mate has tried 3 thermostats and same result with all of them.
    Ducati don't offer different temperature thermostats.
    The problem is (we think) the ambient air sensor makes the ecu over compensate for the cold temperature, and by running so rich the engine also runs cooler than normal.
    at least blocking off some of the rad helps to get the engine temp up a bit (old school racing practice, admittedly from pre ecu controlled injection days when running carbs)
  4. Bradder, my 10 used to run mid 80s, and low 90s when in South of France.
    My 12 runs around 64 most of the time. When it's cold it barely registers 60.
    These are out of traffic temps too.
  5. Does seem low, like I say mine is mega consistent from 2deg outside temp to 22
  6. 2015 Accessory Pack Pricing
    I just checked the Ducati.co.uk web site and the 2015 accessory pack prices are now available:
    • Urban Pack £586.30 [97980041A]
      • Agile and powerful to take you through the traffic and on to your destination, the Multistrada 1200 is at home along bustling city streets. The ideal kit for downtown life is the Urban pack, including a semi-rigid, lockable tank bag with a windowed smartphone pocket and a USB hub to recharge electronic devices. Also part of the pack, with enough space for two helmets, a 48-litre top case fitted with a handy quick-release mechanism.
    • Sports Pack £953.86 [97980051A]
      • When each bend in the road is an invitation to aim for the next and you begin to feel a surge of adrenaline as you lean in and hit the perfect apex, the Sport pack is for you. A front mudguard and Ducati Performance by Termignoni exhaust for a great sound, both in carbon fibre, plus stylish aluminium reservoir covers add a visibly sporting touch to the new Multistrada 1200.
    • Touring Pack £953.86 [97980031A]
      • No matter where you're heading, this pack will keep you on target for your destination with a selection of useful gear for long range road trips or weekends away from home. Side panniers for added storage space, totalling 58 Lt, match the sleek design of the Multistrada 1200. A convenient centre stand provides extra stability and heated grips make all the difference for colder climates.
    • Enduro Pack £953.86 [97980061A]
    All prices are valid from 1st January 2014. Information on this site has a mere indicative value and is not binding for Ducati. Ducati will not be liable for any mistakes and reserves the right to make changes and improvements to any products without obligation to give prior notice or to carry out changes to products already sold.
    Have products shown in this catalogue installed, mounted, removed and/or repaired exclusively by entities belonging to Ducati Motor Holding S.p.A. Authorised Network (dealers and/or authorised workshops).
    #46 steveb123, Nov 18, 2014
  7. So in effect the 2015 MTS s model is £1000 more expensive than the current model considering the 2014 model already comes with panniers etc. Ummm
  8. Yep, clever marketing to get you to pay more and they re coup there costs as I doubt the panny set is any more to produce than last years model.
    So for a full set you go for the 'Touring pack' then pay another wedge for a top box. Mmmmmm...........nearly 18k for a 2 wheeled tourer.
  9. WARNING - OLD SKOOL OLD FART LUDDITE ALERT!!!! ....
    I will never buy anything that comes with the option of any kind of fucking 'pack' - fucking Audi fucking marketing bollox - makes me wanna puke!
    END OF ALERT ....
  10. I assume you can use your existing topbox, just need to buy the rack to fit the new bike, unless they've buggered that up for us
  11. Agree!
    So if I want heated grips only......they are £953?
  12. No. I was talking to my dealer, and they said you can buy the parts individually, as before. That makes me wonder if the "pack" is essentially a discount...maybe. Or the individual parts are more expensive... ;-)
  13. Normally pack are a discount on individual parts, but often you only 'need' 2 of the 4 items, and 'for only £100 you may as well take the pack and get them all' rings out
  14. Looking on the web site it only lists the top box in touring accessories section, makes me wonder if you have to buy the top box to get the rack to fit it to the bike! Hoping you can buy the rack on its own and use your existing topbox, suspect not.
  15. Good question.
    When the GT was released complete with top box, the parts list for that model had all the individual bits for the rack fitting kit, so I was able to order a replacement spacer (between the rear under fairing and the support bars).
    The web page for the rear top case kit indicates that the kits fits all models from 2010 to 2015. Maybe the rack mounting kit is the same even though everything they would bolt to has been redesigned on the 2015 model.
    Also the top case is available with panels in various colours to match the bike (red, black, matt chrome, race titanium and pearl white) except that the 2015 1200S model is available in iceberg white. Also, all the photos I've seen of 2015 models with top boxes have silver panels, the same colour as the new "one colour suits all" panniers.
  16. Does anyone know if the original panniers will fit the 2015 model..?
  17. Most of the accessories for the 2015 model that make up a pack are now listed on the Ductai.com website however they are are not yet on the Ducati.co.uk website which shows the UK prices.
    For the Touring Pack, it's about a 10% saving based on price of the "old model" accessories (centre stand, heated grips and panniers), a total of £1,039 compared with a pack price of £954.
    The Sports Pack looks similar however there are 3 different prices for carbon front mudguards, depending on year.
    The Urban Pack doesn't look as good value if the Givi 3D604 Tanklock Tankbag and S111 Power Hub are factored in along with the Ducati top box.
    The Enduro Pack is not straightforward as it includes a larger, thicker sump/engine guard for which there are no details yet and nothing similar for estimating the price.
    Also the keyless fuel cap (hands-free tank filler plug) isn't yet listed as a 2015 accessory, nor are liners for the new panniers.
    I'm taking a keen interest in the details and pricing of the accessories having put £200 down on a 1200S in white :)
  18. I would doubt it Boomer... If they are by Touratech, then surely different fittings?
  19. 2015 Individual Accessory Prices
    I just checked the Ducati.co.uk web site again and the 2015 individual accessory prices are now available:
      • Kit Topcase 96780581A £479.40
        • New part number for 2015, although the "old" type is still shown on a 2015 search
        • Old price was £440
      • Tank bag with tank-lock fastener 96780511A £180.45
        • Different photo from that originally posted, doesn't look like a standard Givi model
        • Looks expensive but good design for touring
      • Power extension cable with USB port 96680441A £84.35
        • Expensive compared with Givi S111 but has Powerlet plug to connect into the outlet in the fairing
      • Pack pricing gives £157.90 (27%) saving over buying individually
      • End silencer in type-approved carbon 96480711A £714.25
      • Carbon Fibre Front Mudguard 96980671A £255.18
      • Billet Aluminium Brake & Clutch Reservoirs 96180291A £84.35
      • Pack pricing gives £99.92 (10%) saving over buying individually
      • Set of rigid side panniers 96780571A £692.90
        • Old price was £632.29
      • Heated grips kit 96680451A £212.50
        • Old price was 212.63 - can't be right, the price was gone up :)
      • Center stand kit 97080061A £191.10
        • Old price was £182.35
      • Pack pricing gives £142.64 (15%) saving over buying individually
      • Set of additional LED headlamps 96680431A £319.20
        • Old price was £295.58
      • Aluminum radiator protective grille 97380351A £201.10
      • Billet aluminum footrests 96280241A £148.80
        • Touratech price £129.79 (link)
      • Engine cover plate 97380341A £174.00
      • Engine cover in steel tubes 96780561A £261.60
        • Touratech price £269.55 (link) - less than Touratech, must be a mistake :)
      • Stand support plate 97380331A £41.65
        • Touratech price £26.95 (link)
      • Pack pricing gives £319.20 (20%) saving over buying individually
    So prices for accessories are generally up by a fair bit.
    Still not seen any pricing for keyless fuel cap, but I'd assume this is the same as before#.
    #60 steveb123, Nov 21, 2014
    • Useful Useful x 2
