I’m planning on using the 50mm half system eprom and seeing how that goes. I won’t be using a PC3 to piggy back either the standard eprom of the half system, that’s for sure. If needs be, I’ll swap back to the original injectors that, to be fair, I had no issues with. Andy
You are not wrong Andy. Chris Butcher then persuaded me to take both rights as hard on the throttle as I dared using all the kerb on the left before and after the right turns. Made a huge difference tot the lap-time. Same for that very long left turn four, use the kerbs way over to the right long after the exit.
