999 749 / 999 Modifications - What Did You Do ?
Discussion in '749 / 999' started by Dubs, Aug 12, 2015.
  1. I just stuck mine on with no adjustments and it was perfect.
    Usefully quicker throttle without being radical and on mine, it had the effect of eliminating any free play, which I really like.
    No waiting for the point at which it opens the throttles, it opens them immediately.
  2. The bike already came with a straight through exhaust and power commander, complete with dyno read out for 130 bhp.
    Also came with 180 section rear tyre, which allegedly sharpens up the handling.
    I fitted lots of stainless and titanium fasteners to replace tarnished steel ones.
    R1 throttle as mentioned.
    Quiet clutch mod with open cover and stainless springs, bolts and anodised Ducati performance pressure plate. Also ended up with reduced number of plates, which unintentionally really reduced the lever pull.
    Black Cnc machined Chinese levers. Work better than standard and look enormously better too.
    New Yuasa battery, plus cable kit gives instant starting, every time...
    14 tooth front sprocket for smoother low speed running and even more grunt.
    Discreet small black Oberon street fighter bar end mirror to fill in the centre blind spot left by the standard mirrors. Really helps with confidence when joining motorways, changing lanes etc.
    Osram bright white bulbs plus bright white LED in the parking light holder to act as high vis running light.
    LED multidirectional super bright bulb in place of standard stop/tail bulb.
    ExactFit cam belts. Every bit as good as oem and much cheaper.
    Iridium NGK plugs. Enables a bigger plug gap, which gives a fatter spark, so better starting, no fouling, better throttle response and virtually never need replacing.
    Various bits of carbon fibre bling.
  3. +1 on the Titanium...I have just ordered all new titanium sprocket nuts and front/rear bolts, those things ain't cheap!
  4. Titanium sprocket nuts will mess with the rear wheel speed sensor and give problems with engine management, I'm told :(
    Edit: I have since been corrected, it is the rotor nuts that need to be steel in order for the sensor to work, not the sprocket nuts!
    #44 Loz, Aug 26, 2015
  5. I found that but solved it by embedding steel ball bearings in clear silicone in the cap sockets.
    Got the ball bearings from Halfords, they are for bicycle bottom brackets and are the smaller of the two sizes.
  6. Ah ok, I know titanium has a trace of iron in it so...
    Pure titanium metal is mildy paramagnetic, +150.0x10^6 cgs units according to the web, so causes substantial MRI artifacts. It is much less magnetic than common steels, down to non-magnetic stainless alloys, but maybe with a magnet being present there it will have an effect...anyway thanks Loz for bringing that up at this time of night! My head now hurts!
  7. My speedo didn't work and the engine management light came on, so the ball bearings were necessary.
  8. Sprocket nuts have nothing to do with the speedo sensor.
  9. Do you have titanium sprocket and rear brake disc nut/bolts, I remember reading your bikes spec and see you had titanium?
  10. Abs
    Absolutely right. It's the disc bolts I had to embed steel ball bearings in.
  11. I have titanium sprocket nuts but stock rear rotor bolts due to the problem with speedo sensor with titanium bolts.
    • Useful Useful x 2
  12. I have titanium for both and no (related) problems
    Smug, moi??
  13. Hi Nat,did you get an answer to your question?
    I have a similar problem with a Magnesium rear. Do you know if the cush drive rubbers are different to those fitted to the alloy wheels as mine seem to have too much play in them?
  14. Awesome Bike!
  15. Everytime I see these kind of posts I think it's time to get my 749R out of the lounge and back on the road. Now a baby on the way so doubt that will be getting day light anytime soon....
    So the Mod list
    Ducati 749R Number- 630 Mileage 5k,
    Full Engine Rebuild and Blue Print Buy Jeff Green Of GTEC
    BST Carbon 5 Spoke Wheels
    EVR Carbon Air Box and Air Tubes
    Bucci Ball Bearing Slipper Clutch.
    Ohlins Rear Shock DU5100 From 999R 2006 Xerox. Spring changes for my weight
    IRC Black Billet Brake and Clutch Master Cylinders with Fold up Levers
    Brembo Reservoir Pots with Black custom Brackets.
    Full Termi 57mm Exhaust - Black Ceramic Paint and Heat Wrapped at headers
    999R 2003 Carbon Mono Seat unit custom painted by Altamura with exposed carbon and carbon pinstripes
    Ducati RS Water Pump Connectors .
    Ducati RS Vertical
    Cylinder[​IMG] water union
    Ducati 749RS Billet Overhead Shower Throttle Trumpets from the Supersport Kit
    Ducati RS Carbon Water Pump Cover.
    Ducati RS Carbon Under Exhaust Heat Shield
    Ducati RS Style Bursi Seat Bump Pad
    Ducati RS Titanium Engine Bolts
    Ducati Per.Carbon Heat[​IMG] Shield
    Ducati Per. Magnesium Head Light Bucket.
    Ducati Per. Titanium Rear Sets.
    Ducati Per. Titanium. Ride Height adjuster
    Ducati Per. Titanium. Sprocket Cover
    Ducati Per. Carbon Race 1/4 turn fuel cap.
    Ducati Per. Long Carbon Hugger.
    Ducati Per. Oil Plug.
    Ducati Per. Ohlins Adjuster.
    Ducati Per. Frame Plugs.
    NCR Titanium Clip-on’s.
    NCR Titanium. Clutch Cover..
    NCR Titanium Rear Axel Nut.
    NCR Bolts
    NCR Titanium Rear Subframe
    TPO Titanium
    Stem Nut
    Carbon Rear Brake Protector.
    Carbon Swing Arm Covers.
    Carbon Key Guard.
    Carbon Under Seat Pods
    Carbon Number Plate Hanger
    Pro-Bolt Titanium Sprocket Nuts
    Oberon Clutch Slave Cylinder.
    Ducabike Ohlins Clamp
    Motafix Tank Pad.
    Power-Bronze Screen.
    Steel Crankcase Protector.
    Rizoma Rear
    Brake Reservoir.
    R&G Front Fork Protectors.
    R&G Swing Arm Protectors.
    Gilles Black Chain Adjusters and lifters
    DID Gold Chain.
    Billet Rear Under Slung Brake Hanger
    999R
    Suspension Rocker
    Samco Hoses
    Pro-Grip Handle Bar[​IMG] Grips
    Sargent Seat.
    Driven 38T Rear Sprocket
    Hel Brake Lines[​IMG]
    Clear Stomp Grip Tank Pads
    All Original Parts and 3 sets of Original Carbon Fairings ,Nose cone and Carbon Seat Units.
  16. Wish I had the space ,and accommodating missus, to be able to park mine in the lounge...nice one mate.
  17. The rubbers are different to the standard wheel.
    I'm looking at getting a set asp, I'll let you know how I get on..
    • Disagree Disagree x 1
  18. Perfect time I'd say...
  19. Thanks Nat. I'll make enquiries as well.
  20. I have a monster 1100S fully loaded which is a hoot to ride. Running both at the same time isn't good on the wallet. I wonder what I would get for my 749R if I have to sell it. Prices seem to be around £9500 for lightly modded bikes.
