Just used mine for the first time in anger at Almeria, sublime at high revs, but like has been said above at slow speeds I just used the clutch.
Thx @domRusty Super, my fear was that there would be interference at low speeds, I don't know if it'll add anything for me road wise:Happy: but if its on and I sell the bike its quite a good upgrade to have in a buyers eyes,
Bringing in "behaviour" eh? Does this mean I'm running close to the banned line with the microglasses checkin me out!:Locktopic:
Darth Toro has not yet slapped my arse, but if your comment is to assist in keeping it this way then hint taken! If I continue with the poor spelling after this episode at home then I promise to take spelling lessons although 11 years of schooling didn't help me!
Just fitted an R1 throttle tube. I found the original just to sloppy and this has really sharpened it up, especially if you like to "blip" on down shift. So now I think Ive done the three most beneficial mods Cables Throttle Oberon slave Got to look at brakes next
Check out Dragon Plate for all your carbon porn needs. As long as you have the mounting hardware, they can accurately cut to length. They may even drill the holes if you asked nicely http://dragonplate.com/mobile/product.asp?pID=5913&cID=224
None of the above answer the question - I just wondered if @jusutus had laid up and cured the bars himself from prepreg CFRP or whether he had bought some pre-made CFRP bar material and cut/drilled it to suit his bike.
Bought some 22/18mm carbon tube (roll wrapped), cut it down to length, added some OEM bar ends and some £2 blanking plugs and voilà. They weigh about 65g each.
Updated mod list for this year: -Brembo M4 Monobloc calipers with titanium bolts and DID ZCOO ceramic sintered pads -Fren Tubo Carbotech brake lines from 1098 -999F06 Brembo narrowband full floating rotors 320x6mm with 5mm spacers and titanium bolts -Braketech Axis full floating rear rotor -ABM Synto levers -Oberon reservoir covers -Gilles Tooling chain adjusters with titanium bolts -titanium front and rear axle nuts -Supersprox 520 conversion with titanium sprocket nuts -Öhlins DU510 rear shock -DP billet steering damper bracket with titanium bolts -Speedymoto black top triple with titanium bolts -Motoreva stem nut with RAM mount -Speedymoto clip-on clamps with carbon fiber tubes and titanium bolts -DP forged Marchesini wheels, repainted and with new decals -RCM Racing 999RS replica rearsets with titanium bolts -999R Xerox black rear brake pedal -original blue Öhlins decals removed all around, replaced with black decals -full 57mm Termignoni system with titanium silencer and mounting bolts, slightly polished -Pipercross filters -oversized carbon air runners by MS Production -DP ECU -Shorai lithium battery -STM Evoluzione 48t slipper clutch and titanium cover -Oberon clutch slave, new version pushrod with titanium pin -Samco hoses -999RS water union -DP magnesium valve covers -Ducati Corse 999RS04 sandcast, vented and numbered clutch casing with titanium bolts -999R 2003 full carbon tail with carbon seat pad cover -DP neoprene seat -DP magnesium headlight housing -DP magnesium mirror brackets -DP carbon silencer cover, vented with black mesh and new decals -DP carbon air runner covers -DP carbon front fender with titanium bolts -DP short carbon hugger with titanium bolts -DP carbon mirror covers -DP carbon/billet tank cap -DP carbon V piece with titanium bolts -DP vented carbon belt covers with titanium bolts -DP carbon tail tidy with titanium bolts -DP titanium front sprocket cover with titanium bolts -DP windshield without parking light, with titanium bolts -MS Production carbon tail light heat protector -carbon swingarm protectors -carbon ignition switch protector with titanium nuts -carbon tank front & rear protectors -carbon seat side pieces -carbon rear brake m/c cover with titanium bolts -carbon license plate back plate -carbon battery cover plate -more titanium bolts around the bike, +200 in total -Motion Pro coolant recovery tank -horn moved from belt cover to under the headlight -front fairing vent meshes painted black -integrated 5V microUSB charging cable Still waiting for my carbon front and side fairings from the painter. :Shifty: Need to take some proper DSLR pics once the bike is washed and waxed.
Man that's beautiful chap, that list is longer than the build list the builders gets from new!!! I see you really like DP stuff, is it cause it Ducati or you prefer their designs? The red and black frame on the 749/999 look sooo much better than my silver, think I'm going to need the chop mine in for the later model and my spinal recovery is getting better so sports bike remain maybe a late 999 this time
