749r Dry clutch
Discussion in '749 / 999' started by Red Duck, Jun 1, 2013.
  1. where was it at and did you have to alter it?
  2. well it was a race kit with errrrrrrrr (forgot) 8 or 9 slim alloy friction plates
    now
    I didnt use the original stainless rings and used the fatter ones I had already as I thought "they look bloody slim"
    the kit had about 4 convex rings in upon very close inspection.
    all the kit stainless rings were about 1.25 / 1.3 mm (new) and the carbon/kevlar friction plates 2.5mm
    I gapped it according to your advice having about 3.35mm from the inner drum.
    I googled on the web and fitted all 4 convex.
    its now lovely. clutch feeds in nice and no slippage upon testing it...
    this must be a discontinued kit as I cant find any reference to it. but is a genuine DP part (came in box from a ducati shop)
    I had it for months before I finally fitted it.
    your da man - respect :thumbup:
    (edit)
    and to top it off i had started with a stainless ring
    #42 Phill, Jun 2, 2013
  3. I'v been looking at the service history of my 749r today.
    The clutch was serviced about 4000 miles ago.
    One item says 'clutch stripped, inspected, cleaned and plates SHUFFLED for best wear'.
    Could this be causing my clutch problems ?
  4. even if it was new its tosh, 3 ramps no balls so its very uneven and unsupported to the drum can move causes stuff to rattle screech and scrunch...junk it! get a 6 ramp and ball one.....
  5. If money was no object then I would ' junk it '.
    So off the top of your head, how much ?
  6. hmm new £600-800...........second hand £200-300
  7. I disagree.
    It's not "The Best Slipper Clutch In The World" however....it does work if it is adjusted correctly and properly maintained.
    I have a 6 ramp/ball slipper in my 916SPS (which is currently having a "Year Off").
    If the R clutch was SOOO terrible I would swap them over. It ain't, so I CBA.
    R XX
    #51 RickyX, Jun 18, 2013
  8. I hope your right Ricky. My mate is going to strip my clutch down on Saturday and see if he can improve it.
    Fingers crossed. :smile:
  9. you can lead a horse to water...........
  10. ......a bit harsh
  11. thats not how it ends....:biggrin:
  12. No more money to spend till the end of July. So must try to fix it a bit !:smile:
  13. Grease ya ramps and check your stack height...:upyeah: Google is your friend and lover...:smile:
  14. ah money................the root of every problem
  15. Quick question . We are just about to re stack the clutch plates. one of them has a stamped dot. Anyone know what it means ? thanks
  16. thats a spring plate.........sometimes there is one ....there can be two or even four.......
