848 virgin
Discussion in '848 / 1098 / 1198' started by Blanco, Mar 13, 2013.
  1. Been there, done that. It's really no different to my old crossplane crank R1.
  2. Well, all i can say is if i gave my gsxr1000 a big handful and then quickly shut the throttle it would not engine brake as much as the 1098 does. I assume its down to having x2 549cc pistons as opposed to x4 249cc pistons. Maybe someone more technical could explain.
  3. Sorry timberwolf :wink:
    Conventional Quickshifters vs. Strain Gauge Quickshifters
    CONVENTIONAL QUICKSHIFTERS
    By ‘conventional quickshifters’ we mean all qui
    ckshifters that do not use a strain gauge.
    This includes ‘pressure sensors’, ‘transducers’ etc.
    All conventional quickshifters use some sort
    of switch, which is
    a mechanical device.
    This makes conventional quickshifters very
    susceptible to vibration and shock and as
    such they will fail after a time.
    Practical testing has shown that the best
    conventional quickshifters expect a maximum
    of a season’s race usage. However they often fail
    a lot earlier as any team mechanic will tell you.
    They are also completely unsuitable for
    road use, as the high vibration and shock
    experienced on public roads destroys
    a conventional quickshifter quickly.
    As a switch needs mechanical movement to
    be activated, the operation is distance
    based. i.e. The gear lever needs to move
    a certain distance for a quickshift to be
    initiated.
    A conventional quickshifter relies on a spring
    or other pre-tension mechanism to hold
    the switch open. The strength of
    this spring determines the am
    ount of force required to
    initiate a quickshift.
    This is not adjustable - which is a probl
    em as different rider
    s, gear linkages and
    gearboxes require different am
    ounts of force to shift.
    STRAIN GAUGE QUICKSHIFTERS
    As an alternative, strain gauge or load cell qu
    ickshifters completely eliminate all of the
    problems associated with conventional quicksh
    ifters. This is because there are no
    moving parts at all. The quickshifter works
    by measuring the molecular change in the
    shift rod when a force is applied to it. This
    makes them very precise devices and.
    This is why high budget race teams use
    strain gauge quickshifters - they are far
    superior in every way.
    Another major advantage is that as the st
    rain gauge measures force applied to the
    lever, it is not distance based, but load bas
    ed. So a quickshift will occur at precisely the
    right point every time without the need fo
    r any setup. i.e. With a strain gauge
    quickshifter, the selector drum
    is always loaded when a quickshift is initiated ensuring a
    perfect and smooth shift every time. This
    is also very gentle on the gearbox.
    In addition, unlike all other quickshifters, stra
    in gauge quickshifters are adjustable. This
    ensures that the correct amount
    of force is required at the
    lever to have a perfect shift,
    regardless of rider preferenc
    e, linkage setup or gearbox.
    The major down side of strain gauge
    quickshifters is cost and complexity.
    COST: Strain Gauge systems can cost thousands.
    COMPLEXITY: The actual strain gauge is us
    eless without an external amplifier and
    complex electronics to interface to the bike.
    HM are unique in bringing all
    of the advantages of a stra
    in gauge quickshifter into one
    complete and compact package. This package
    includes everything required and simply
    plugs into any existing bike loom - all at
    a price that is compet
    itive with conventional
    quickshifters!
    (please see our document “Strain gauges vs.
    Load cells” for more technical info)
    and finally......ask any rider that has exper
    ienced using a strain gauge quickshifter and
    he will tell you that there is
    no comparison. Reliable smooth and slick shifts every time!
  4. Aha I see.
    It does the same as my standard quick shift :wink:
  5. So is an evo corse SE quickshifter conventional or strain gauge cos I'm hoping its gonna last more than a year
  6. Like I said in my original post "if you are happy with what you have......" :upyeah:
  7. Conventional, the warranty is 2 years so you'll be fine :biggrin:
  8. Well I've not been convinced to be unhappy so far :smile:
  9. :cool:
  10. In the same way a showa rear shock does the same as your ohlins.
  11. ok - I have the HM unit - not a clue what its supposed to do lol
    How am i supposed to use it? Just do clutchless upshifts?
  12. Keep throttle pinned, no roll off, just 'kick it up'
    Or so I'm told
  13. Correct :smile:
  14. On a very long straight road lol ( or track )
  15. Incorrect. You can do it on roundabouts too. :smile:
  16. Honestly given the length of first on my 1198 I seriously think I would end up on the moon if I did that lol
    Will give it a whirl on a long straight road first and maybe test the roundabouts later !
    Is it actually assisting the clutchless upshift (which I do anyway) or is it just cutting the throttle to allow no roll off?
  17. it assists clutchless upshifts. No blipping of the throttle is necessary. You just keep the revs constant and flick the lever up, and hey presto.
    Piece of piss. :upyeah:
  18. Just picked up my evo corse SE chuffed to bits with it can't wait to get it run in. I don't think it has got a lot of engine braking but I haven't been over 6000rpm the quickshifter is awesome but it takes some getting used to I shifted up a couple of times when I didn't want to the lever is so sensitive, can't wait to use it flat out apparently it works even better at high revs :)
  19. The Baron is the Alan Partridge of motorcycling. Extremely funny.
